Cranking time question
03-30-2013, 06:07 AM
I recently installed the SE pro stage 4 kit on my wide glide. I noticed along with the humongous gain in power, the crank time on startup is considerably longer. Before it was starting almost immediately now it take a couple seconds. Is this something I should be concerned about and if so how do I fix it? Thanks in advance.
03-30-2013, 06:59 AM
Do you have compression releases? If not, that could be your problem. If you do, don't forget to use them.
03-30-2013, 08:09 AM
Quote:
Originally Posted by
tomt
Boinnggg!
03-30-2013, 03:03 PM
The 2013's come with the automatic compression releases installed from the factory
03-31-2013, 05:01 AM
You have a SEPST as part of the build?
If so, check that you have ACR Enabled in Tuning Setup.
You could also look at increasing your Cranking Fuel values a little.
Oh - did you swap the plugs for anything different as part of the build?
03-31-2013, 07:51 AM
That's a good idea ill look into it. Yes I put in the SE plugs instead of stock
03-31-2013, 08:00 AM
adegeorge
If the ACR check comes to nought then it might be worth investing in some stock plugs just to see if it makes a difference.
Xscout577
09-30-2012 09:25 PM
tem2169
Exhaust System Topics
36
05-23-2012 11:07 AM
mikeurig
11-03-2009 07:01 AM
Gearhead1
02-08-2009 03:16 PM
bcasinger
08-25-2008 03:42 PM
