Throttle forward rotation
It shouldn't rotate past the idle position, you know when its stretched because the adjuster won't take up the slack.
You have to adjust the pull one first so wind the adjusters in on both cables, adjust the pull and the adjust the push.
You can just replace the stretched one but often adjusting them correctly can help a lot.
travalab
05-16-2017 09:04 AM
