First Oil/Filter Change
Old 04-01-2013, 11:09 PM
Sharpie's Avatar
Sharpie
Sharpie is offline
Default First Oil/Filter Change
Changed the oil and filter for the first time on the 09 Dyna. I bought it a month ago with only 678 miles on it. This is the first time oil and filter change since new. Drained the oil last night and put the oil change funnel under the filter. I poked 2 holes in the filter and let it drain all night. Today I went to remove the original filter with my Craftsman 3 fingered tool and the place where the ratchet went was broken. As my luck would have it, Sears did not have another one in stock and would have to order it. I thought I would try a Fram filter wrench that I had purchased but never used. No luck too big. Went to Wallyworld and bought a filter cap wrench. All it would do was spin on the filter. Went to Azone and bought a 3 fingered wrench like the Craftsman one I originally had. It would not lock on to the filter and only slipped as well.
Finally took off the regulator so I could get to the filter with large pipe pliers. I got it to spin about 1 round and now it would spin with my hand. Once I got it off I hd the choice of a Mobil1 black filter I had or a K&N Chrome I had puchased. Because of the nut welded to the end of the K&N, I put it on and will take the Mobil1 filter back and exchange for a K&N Chrome.
I had only read tales of people having problems getting that original filter off of the machine and thought it can't be that hard. I was just before driving a screwdriver thru the filter to be able to turn it but didnt want any oil on the engine block. The filter funnel works great and was well worth the $20 I paid for it. New K&N and new Mobil1 V-Twin 20W50 in the engine. Now to get to the primary and Tranny fluid changes. Got Mobil1 75W90 Gear Oil for the tranny and Mobil1 Racing 4T 10w40 for the primary.
I carried all of the filter wrenches back and got a refund. Their wrenches work just not in my situation. I think when Sears gets my new one in to replace the broke one that I might just get my money back on it as well. I don't need them on the K&N filter.
The HF yellow mc jack sure did come in handy when working on the filter and then when detailing around the filter to make sre it was all clean.
My bike and I now belong together as we have exchanged fluids.
Old 04-02-2013, 02:37 AM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
+1 on the K & N's with 17-mm hex to get a ratchet/socket on. Before that, I used a cap wrench that my Schucks (O'Reilly) sells, made of dark gray composite, it's the #5 or #7 (don't remember which, they sell several sizes). It worked better on the Dyna; could kinda squeeze it past the Crank Sensor, but on the Road King, I had to remove the Sensor...no more.
Old 04-02-2013, 08:37 AM
mattVA's Avatar
mattVA
mattVA is offline
Did you use the Harley oil change funnel or something else? With the two holes and what you used was there any leftover mess when you took the filter off?
Old 04-02-2013, 08:51 AM
128auto's Avatar
128auto
128auto is offline
The oil filter tool costs $10 on eBay, you need something to clear the crank sensor. Sorry, I'm not a fan of the ugly k+n filter with hex head lol. I also bought a screw in type long funnel, no more messy fill!
Old 04-02-2013, 09:55 AM
milesvdustin's Avatar
milesvdustin
milesvdustin is offline
I use a Purolator Pure One filter on my bike. I use them on everything else, might as well use it on the bike. (Yes, I checked that the check valve and all was the same PSI requirements and all.) I like that it is textured to grip easily to remove. As far as mess, I just spray it down with degreaser and hose it off.
Old 04-02-2013, 10:18 AM
01ragtop's Avatar
01ragtop
01ragtop is offline
I use the Chrome Amsoil filter. To remove it I use the small craftsman rubber strap wrench in this link.
http://m.sears.com/productdetails.do...00P&sid=&psid=
Just clean the filter and spray the strap with some brake cleaner so it gets a little more grip. It takes some patience, but it always works and I never have to remove anything else.
Old 04-02-2013, 10:25 AM
omaho5's Avatar
omaho5
omaho5 is offline
Very romantic story. Please do not use your tounge on any of these fluid swaps.
Do not let your GF/wife know of this romantic fling.
Old 04-02-2013, 10:40 AM
oubronco's Avatar
oubronco
oubronco is offline
Bought one of these on the discount shelf at the local dealer for $7 works great
http://www.dragspecialties.com/produ...oductId=130142
Old 04-02-2013, 10:48 AM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Oil Filter Wrenches
I was done with all the cap filter wrenches a long time ago. A strap wrench with either a rubber strap or a fiber/cloth belt ALWAYS gets the filter off without much effort. I prefer the fiber/cloth ones because they fit on the end of a ratchet and are never a hassle to use.
If you had punched a screwdriver through the filter body, you could have made a mess plus it still might have been impossible to get the filter off that way. I had one that tight years ago and did the screwdriver trick to it...Had to tear all the filter body off to get to the base plate of the filter and then beat it off the mount with a piece of rebar...Never again.
http://www.napaonline.com/Catalog/Ca...017_0361131939
Old 04-02-2013, 04:08 PM
Id.Fat Bob's Avatar
Id.Fat Bob
Id.Fat Bob is offline
Good post and thank you...do you have the Purolator PN...I use them too and would like to run them on my FB! Not too proud of the color tho...but what the hell!
Quick Reply: First Oil/Filter Change
