Vied Install question
For those that have installed Vied's on a Wideglide; did you have to remove the battery. I can get to the black O2 connector under the seat, but it doesn't look like I can get to the grey one without removing the battery. This is for a 2013 Wideglide. Also, if you didn't ground to the battery, where did you connect the grounds?
