HD Dyna Oil Cooler
HD Dyna Oil Cooler
So I buy a HD Premium oil cooler and the first instruction is to glue the cover on too the cooler with high performance sealant,,Side note on instructions ( additional parts required ) Sealant,,,Cheep bastards don't even give you the sealant LOL,,,I can just see it flying off on the freeway and sticking in the front grill of a Mercedes ,,Not a big fan of two face tape or glue holding parts on a bike or car,,,So I made a simple bracket to hold the cover on with some scrap aluminum ,,, Drilled cover,,drilled bracket and taped,,Cover is not going to fall off now,,Just need to clean it up and paint it now,,,It's also faces the frame when mounted so you well really never see it,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,
Been wondering about an oil cooler for my bike...............just to keep it cooler. I've heard so many pros and cons about oil coolers. Needed/not needed, etc. Kinda like the dealer download. <----Some love it, some think it's a waste of money.
What's the REAL deal on oil coolers. Cooler bike, or waste of money?
10Over, Nice fabrication. Obviously the other poster doesn't share the same opion we do, quality and time spent are far more important than cost. In the long run quality workmanship will leave an impression far after the memory of saving a few bucks wears off or is gone from your mind.
Bob
Bob
Bob
Bob
FYI, Jagg now sells both a vertical and now a horizontal fan assisted oil cooler. You also need to get the oilfilter adapter, so its not cheap for the entire kit.
http://www.jagg.com/hd-dyna.html
I am having the horizontal installed, used to have a vertical but wanted the extra cooling from a fan as I have been stuck in traffic and the parade mode kicked in.
