weird random no start issue
I have a buddy with an 08 Street Bob that is acting up. Sometimes it starts right up and other times the key signal on the dash comes on and the flashers blink but it wont crank. So far we've been able to get it started after shaking the bike back and forth or messing with the key position for a bit. We havent found a method that works every time so before he takes it to the dealer, do any of you guys have any ideas for things we can check? He already changed the battery in the key fob. Any ideas or suggestions are appreciated.
He said he checked that already but it wouldn't hurt to check it again--possible replacement battery was on the shelf to long. One other easy check would be to spray some contact cleaner in and around the ignition switch. A lot of us wash our bikes so much that excess water in and around ignition switch could cause some rusting up in there.
Also loose wire, on starter relay, or in between.
Once in a while my FXR4 does this. wiggle wires, then it starts - but nail it down. The switch maybe faulty or a intermittent connection...
No siren? the flashing turns stop after you just turn on the bike w/o hitting the starter? If not the alarm was triggered so like a previous poster, check the ant and maybe the unit's connector is loose or wet.
Trying to nail down where the antenna module is located. Ive been searching posts and one person said its a 3" long, 1/2" square, all black connector under the seat. Another person siad its under the left side cover. So Im guessing the actuall module itself is under the cover and the connection is under the seat? I really dont think its the fob because he has two and it does the same thing using either one.
Thanks fskitch. Im going to have him check it out. He also had some bullshit "flash to pass" automatic garage door opener thing installed not too long ago. Just found that out. So we're going to look all the wiring over really well to make sure the installer didnt screw something up. I fricken hate chasing electrical gremlins.
jlwhitt77
05-22-2010 11:07 PM
