bike randomly idling high, help please.
this just started tonight on my way home from work. When I left it was normal. then a couple times when coming to a stop light it would idle between 1400 and 1500 rpm for a bit and then finally drop down to the normal 1000 range. Its a 2012 wide glide and the only mods are vance and hines short shots and a fuel pak. other than this weird idle issue it is running fine.
Could the fuel pak be causing this? its been almost six months since I put the pipes and fuel pak on and it has been great until now.
If its TBW then no thumb screw.
Well took it for a ride today and it doesn't do it any more. I don't know what the problem was but it's gone now. Since I can't replicate the problem I have no way of knowing or figuring out what caused it. I guess I will just check the bike over and clean the IAC and call it a day.
I've had this twice on my '08 Road King. First time was after it was serviced by my Indy - leaving his workshop. We did the Microsoft cure - turn it off and re-start and it was fine, did the same thing about 2 years later, tried the same cure and it was fine. I think sometimes the computer gets a little bit confused.
