2006 FXDWGI Crank issues.
Ok So i was riding, and lost oil pressure.. found out the oil pump was shattered, crank runout was unacceptable.
Got a good used crank, that was supposed to be the correct one. I have a TC88, and this crank is for a tc96.
Can i use this crank, (i dont think i can) however, its already installed, and found out last night that the pistons were hitting the heads.
What would I need to do, CHEAPEST WAY to make this work with this crank?
Well, since it seems like this is a "What harley tells me" forum, does ANYONE know where there is a forum that has ACTUAL wrench turners instead of actual koolaid drinkers?
Btw, casket (yes I am talking to myself) What you would need to do, since the bore is the same as the 96, and it seems like a 96" crank, swap the pistons out, reflash the ecu, and go ride. It is now a 96" stroker motor, instead of a big bore motor.
Thanks Casket for the advice...
appears you already know the answer.
get the correct wheels....... duh....
https://www.hdforums.com/forum/dyna-...23955-06a.html
sounds as if you're going by - "What harley tells me"
kool aid drinker??
m_mcdonnell314
Engine Mechanical Topics
20
06-19-2017 01:41 PM
