exhaust flange is it suppose to sit flush with head? or no? pic inside
sorry made two threads.
installed my thunderheader , when putting on the exhaust flange i notice it has a pretty good size gap on both flanges, no leak though ( put hand around flange didnt feel any air)
on both flanges one nut would tighten down on more threads than the other nut as you can see in this picture, its more exaggerated because the nut on top isnt the factory one (lost it and just used that nut for now)
the spec on the nuts are inch lbs so i just torqued it to hand tight and no more i dont want to crank on the threads anymore, im pretty sure there not suppose to sit flush with the heads just need confirmation
from the pic it looks as though your flange is not sitting evenly loosen all your mounting points and loosen the flange nuts on the rear. loosen the front nutz shown in the pic and wiggle the pipe and make sure it is in there snug. assuming you used new exhaust gaskets, tighten the bottom one first and watch that they seat evenly. do the same to the rear and then finally tighten them a half turn past snug. Tighten the rest of the system and ride around a few miles and then let it cool off and check if those header bolts are still tight. You may have to re-tighten them just a half turn again.
what he said up there^^^^
he beat me to it lolol almost the same thing i just typed
sorry maddghost
it almost looks tweeked to one side
it does look like the top was tightened more, before you snugged the bottom one
just loosen them up and tighten them evenly
if it does not help then loosen up the exhaust mounting bolts then try to even them up
and remember they will need a check once you run the scoot a little while
sorry maddghost
the TOP NUT (brass color) is not the oem one, the bottom one is oem as you see it has more of a shoulder on it (the oem one) so that is why you guys are seeing more threads on that brass NUT, if i had the oem nut on it, they would look the same
the rear pipe has both oem nuts and the threads are level
from what i read your suppose to tighten the nut to where the stud will meet the top of the nut and no more? ive seen other pictures like this one and others say its fine
you can see the stud clearly here so your saying the flange should cover all the stud behind the flange? your bottoming out the entire nut? and dont see any threads behind it? if so isnt that wrong?
