LED Turn Signals Installed - HELP
Hello all, so today I installed my LED turn signals and they work great, but for some reason the red key icon on the console keeps coming on. It's funny because when I start the bike it want come on until I actually hit something that draws power, like hitting the brake or turning one of the signals on. Any idea why this is happening? If so what is the fix? Thanks...
I had a similar issue on my 09 RK, but didn't have the security module. Just the turns stop working (did all 4 and tail). I ended up using the ILL-01-A (item 3) found here:
http://www.badlandsmotorcycleproduct..._&_TURN_MODULE
It has an intregrated brake/run/urn module and a load equalizer. Now your rear turns are brake and running also. Simple plug & plug
If you just want a load equalizer its this one LE-03-A found here:
http://www.badlandsmotorcycleproduct..._EQUALIZER_III
