Crankcase breather kit on S&S carb problem
Ok...I bought a breather kit from JP cycles....
took off my carb cover and back plate...kit fits great. Put the back plate on and it wont fit since the old breather bolt holes on the back plate get in the way.
Bad thing if I cut them off the carb backer? The only thing they were supporting were the breather bolts.
The original owner had rubber tubes about 3" long coming from the stock breathers directly into the carb cover. But the carb cover started cutting into the tubes and blocked half the breather bolt. Contacted JP cycle and they told me this would work.
I put the new breather kit on and it fits nicely, but the carb backer wont fit now with the brackets you see. Tried to fit it other ways but the backer plate wont seat right.
You have to bolt the carb support bracket to the breather bolts. You cant just have the AC/Carb hanging on the intake flange without support from the breather bolts.
