Plug wire ties
Plug wire ties
Quick question.
I put SE plug wires on the bike but they didn't come with the small zip-tie push-plug combo things to secure the front wire to the cylinder brace. For now, I just zip tied it to the brace but I don't like that the wire contacts hot metal.
Where can I get these little dudes?
You can also make your own, for the front cylinder support put a tie wrap on the ignition lead than insert the pig tail of the tie wrap through the hole in the top cylinder bracket, use another tie wrap head to secure it on the other side of the bracket like I did below on my clutch cable. The rear support you can use part of a large tie wrap, poke two holes through it with a soldering iron, and use two small tie wraps to tie the leads together.
What I did was to run the wires over the top of the horn bracket and use a couple of small zip ties to secure it. I also put a small piece of high density foam under the plug wires so they wouldn't rub on the bracket. It's hard to notice and it seems to be holding up fine.
