OK To Mix?
It'll be fine. As long as the tire is something comparable then you won't even notice. The only time that it would make a difference is if you had a sport bike and were taking it to a track. Tire compound characteristics change over cycles of heat/cooling off so even if you bought a new matching Dunlop, the rubber compound still wouldn't be 100% match to your front.
Like I said, this would only matter if you were dragging a knee and going 150.
CookUltraClassic
07-03-2023 11:29 PM
