Need advice on cams
Need advice on cams
Ok..... I have a 2012 Wide Glide with the 103 motor, screaming eagle heavy breather, Vance and Hines 2 into 2 big shots and screaming eagle super tuner pro. I have narrowed it down to the Andrews 48h and the Screaming Eagle 204. I can't really say I'm looking for performance as much as good lope of the cam. Which one would be best for my bike? Just want a good bolt in for now....not really looking to do any head work just yet.
Hmmmm, choosing a cam because of the noise it makes at idle...The Spanner finds this perplexing to say the least....whatever happened to choosing a cam for your riding style???
I like the 203 because it has low down grunt, works on a stock motor and has a good spread of power...but not sure about "lope" its not something my customers ever put into the equation.
You could set the idle too rich....that would make it lope ;-)
Go with the 204s. Great spread of power, the best of the SEs in my opinion. Lovely sound too, I even dropped my tickover to 975 to exaggerate it.
The biggy though is that you will be able to tune it with your SEPST easily yourself. You will be able to throw on the canned SE204 map and call it good, or do a bit of Smart tuning for extra goodness. Use another make of cam and you will have to get a custom map on there to match the cams and that means dyno time.
