12 bob tailight missing.. Lol
Well, I decided to take off that silly looking tailight once and for all.. Got the wires tucked for now. And mounted my license plate using the bottom 2 bolts for now too.. I really like the look. It will look alot better when I get a side mount plate and the holes filled. I know there's a million out there, but does anybody recommend one they really like with a light? Got my power vision delivered the other day and did the auto tune.. All I can say is that my bike runs top notch, and has more *****.. Even if its only a stage 1. Also mounted some new bad a** pedals on today from DK custom and a new ac cover from bung king. Pretty happy with everything. I also have some black 12" 430 progressives on the way.. Gonna raise it up a little for a better ride. Got a good deal on them and couldn't pass it up. Thanks for lookin-
Basically I used my license plate and frame to cover the hole for now.. I drilled 2 holes in the bottom of the plate, and mounted it to the 2 holes on the bottom that held on the tailight.. Quick fix for now, that looks half way decent. I then went to the hardware store and got a plug for the top hole. Zip tied the wires up in the fender for now, until I can pull it back and tie it under the seat in case I ever need it again.
Hey Twelve HD,
Nice lookin scoot!!! I've been thinking about doing exactly the same mod on mine but am waiting for the replacement turn signals to com in as well as a side no plate mount. Quick question, how big is the hole once the rear light is removed? Is it just a matter of bolt holes or is there a larger cut out for the light?
Ride safe..
SE
Ride safe..
SE
Hey Twelve HD,
Ride safe..
SE
Ride safe..
SE
Received 3,939 Likes
Looking good!
I really like the Model A style tail light...and then on the other end of the spectrum is a small led bar that can mount right at the bottom of your plate.
Hey Kevin! Thanks again for getting me those pedals so fast, I reall appreciate it. You guys are awesome! ? About the license plate.. How's the installation on that? Will it mount up to my switch that's already there?
Not sure what you're asking about on the license plate?
We have the vertical and horizontal mount brackets that can be used on either side, down near the axle/lower shock mount.
http://www.dkcustomproducts.com/Lice...cation_c94.htm
But I thought you were liking your plate where you have it now?
Check out noschool choppers and dk custom for sidemount license plates. When I got my noschool, the license light was cracked and they sent me a new lense no questions asked. As for dk custom.. they have a 100% track record in my book. I wouldn't hesitate to order from them again.
As for wiring you'll have to splice into your existing harness.
