motor swap
The motor will fit but I think you'll find the 01-03 has MM EFI and not Delphi, which will cause you problems but you can use the 01-03 injection on the later motor.....have fun tuning it though....that could be your biggest issue.....you'll need to swap throttle bodies and maybe a couple other tweaks but its doable.
