Clutch Interlocking Switch Bypass
Old 04-30-2013, 01:43 PM
maxboxa's Avatar
maxboxa
maxboxa is offline
Default Clutch Interlocking Switch Bypass
i've tried bypassing this switch by splicing the wires together at the clutch hand control to no avail. does anyone know where i can bypass this assembly altogether at the main terminal?
Old 04-30-2013, 03:30 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Bypass should work. Did you try leaving it open circuit?
Old 04-30-2013, 04:11 PM
maxboxa's Avatar
maxboxa
maxboxa is offline
well, i basically soldered the two wires together. unfortunately, this didn't work, though i'm not sure why. this method has always worked for other bikes i've owned. so i re-attached the assembly and glued the button down. this worked for a while, but the vibes manages to break the button loose. i figure if i just link the two at the source, problem solved.
open circuit? never occurred to me that this could be the answer. just goes against everything i've seen in the past. i'll give it a shot though
Old 04-30-2013, 05:06 PM
Spanners39's Avatar
Spanners39
Some of these cut outs work by grounding the system so it doesn't fire.
Max Headflow
Milwaukee Eight (M8)
38
11-10-2020 08:17 AM
13RoadKing
Electrical/Lighting/Alarm
15
04-04-2017 10:27 AM
davidw221
12-20-2014 09:14 PM
onebad2
10-03-2013 08:58 PM
amike
11-13-2007 10:50 AM
Quick Reply: Clutch Interlocking Switch Bypass
