Street Bob wheel swap
05-01-2013, 06:15 PM
Has anyone swapped cast 10 spoke wheels from 2006 Superglide to a 2012 Street Bob? any photos? Did you have to get new spacer? Thanks,
05-04-2013, 05:45 PM
Has anyone done this? Thanks,
05-04-2013, 07:09 PM
You are going to need different bearings as well I believe. My chart is at work. I just checked, 06 is 1" front and rear, '12 is 25mm.
05-04-2013, 08:28 PM
Axle sleeve should work, you may need to measure for new spacers. I took off the laced wheels on my 07 fxdb and put on mags from an 08 fxdc
Yes, HogPro is correct, 06 should have 1" bearings and spacers, yours will be 25mm.
05-04-2013, 10:16 PM
05-04-2013, 11:34 PM
Also, 06 & 07 had double row ball bearings. I think 08 was the switch to single row.
mattVA
10-10-2016 08:05 PM
Linearms
06-13-2016 09:30 PM
Hamhock72
Wheels/Tires
03-17-2015 08:18 PM
EastBay_Solo
11-12-2012 09:39 PM
MAGNYS
12-15-2009 05:07 PM
