NGK spark plugs or stay with Harley?
My local Harley dealer sells plugs for almost 6 dollars a peice, not counting the 2 hour ride back and forth. (hour each way)
The local auto store 15 minutes away sells NGK spark plugs (standard plug I think) and I was wondering what you all thought about using this brand..... or just stay with Harley brand?
2012 Super Glide Custom.
You are getting some bad advice here. It does matter and you should stick with stock.
There is an anti-knock system on these bikes that relies on measuring tiny changes in current across the spark plug gap when knocking happens. Mess with this by swapping to non-stock plugs, leads or coil can lead to this system not working anymore.
You could end up with the anti-knock system not working or on all the time. Neither is good for the engine.
There is absolutely nothing to be gained by using another make of plug. They are mostly a big fat snake-oil scam that has been running for years.
Hd plugs are made by one of the large companies prolly champions like parts eeter said. Plugs are # cross referenced all the time, you don't need hd plugs thats a falicy. NGK iridium if available for your bike are as good as it gets right now but pricy. Snake oil scam?? not true, oil addatives for the most part are snake oil scams but good spark plugs and wires make your bike perform better thats a fact!! But get the right ones for your bike. I doubt hd makes oil too. What hd does is make bikes!!
The only way you can safely swap the original for another brand is that if you find another plug with the exact same electrical resistance so that the antiknock works as designed.
With another quality plug like NGK the plug will look just fine after 10k. But the antiknock might have not worked correctly during that period.
If you bike doesn't have the antiknock, then go ahead with NGK.
