STATOR GROMMET question and Winter Mod Pic
Have discovered a little leak at the grommet of the stator, that part which seats against the casting of the motor. Don't want to change the stator cause working great and only a small leak (hate having it dirty with oil even if it is just a little). Saw that people have moderate success with silicone but before I try this would like to know how far I can pull this grommet out in order to clean it, ¼ of an inch, ½ inch???
Thanks for your answers
Thanks for your reply, that's about how much I pull it out. I see that the end is a little bit dried up.
Yesterday took the plug out and pulled a O-RING over the grommet thus fitting it against the top of the grommett and the motor housing. Wanted to try this before doing the silicone thing. Want to make it last at least through summer so I can do the stator thing this winter.
Will keep you posted to see if the oring thing did the trick. Will know in about a week because calling for rain the next 4 day.
Thanks again for your reply, now I know that I can't pull it more than that.
