i want a full rear fender for my 13 streetbob how do i wire the rear brake light?
I can't remember the part number. My dealer had it in stock. Your '13 should have 3 wires going back under the seat-2 blinkers and the license plate light. They plug into a 3 to 1 harness. Unplug this 3 to 1 harness from the main harness and plug in the super glide harness. It runs back to the light plug(the chrome plastic piece that the super glide tail light screws to) on the super glide tail light. If you are using strut mounted blinkers, they also plug into the tail light plug. I'm sure thats clear as mud. I'll see if I can get some pics.
please post some when u get the chance
Snapped a couple pics on my way out. I'll try to get some better ones. Locate this wire under your seat. See the three wires that come off with connectors on the end-those run back to your blinkers and license plate light. The big connector plugs into the main harness. Unplug the big one and plug in the new super glide harness. It can only go one way.
Run the super glide harness through the new fender to the tail light connector, the piece I'm pointing at below.
Plug the other end of the super glide harness into this piece. I used the panacea tail light so I didn't put any blinkers back on. However, if you are going to use blinkers, they also plug into this tail light socket.
I got mine off of ebay and then bought the wiring harness from the dealer, and an aftermarket tail lamp. I would keep checking back on ebay often. You will probably have to have it color matched.
I saw a vivid black one on ebay the other day that was in good shape. It sold for $350. You can buy a vivid black one (59634-06DH) new from new castle for about $400. Price will vary for the different colors. I don't know what the code for charcoal pearl is.
I'll definitely keep an eye on Ebay.
I hadn't thought about checking the dealership to see if they can get one factory painted in Charcoal. I thought only the 2014 Street Bob and Street Glides came in that color, but it's worth a shot to check it out.
I think the full rear fender is a better option for me since I am putting on Conley bags. I don't like the turn signal and license relo kits that are out there. The Great Bike Gear kit has too much structure that hangs beyond the stock fender and the Harley kit...not a big fan.
Can you post a picture of it for me.
Thanks
