KICK STARTER with S&S Easy Start cams
hello,
At first my bike is a FXDX Dyna sport 2005 EFI model
now it's a Carb bobber , almost everything has been changed
Whell , PM brakes , MIKUNI-42, ALTMANN ignition ...
next --> I was thinking for a new cam to change my chain cam to a new EASY T+START GEAR CAM ( S&S 551 Easy Start )
i was dreaming for a long time for a KICK STARTER so I think it's time now withe the MIKUNI and Altmann ignition mod
found one to fit my 2005 dyna on AMERICAN-CLASSIC MOTOR
but ...
--> a friend of mine said , that I will not succed to start with the kick and the EASY START cams ... because of the dynamique compression missing with the Esay Start cams !!!
don't understand really this ,.
Do you have more news about KICK and Esay Start cam together ?
thanks
but ...
thanks
--> but with ?
because when START-UP , the intake valve stays a bit opened by the cam , still the engine starts , ~ 900 T/mm
after these revs , the easy cam is like a normal gear cam.
the sustem is re-armed , when the engine is shut-down.
http://www.ebay.com/itm/130886517185...S:1123&vxp=mtr
400$ I didn't need a strong model for the 88ci , as I was thinking to mod my cam chain with the latest S&S Easy Start gear cams.
but , now ... ! ! !
KICK is on its way ... so I am waiting for , and look how it works with the stock cams first.
yes ...stock , or cam gear ( without the S&S Esay Start system ...)
--> but with ?
--> but with ?
Your bike looks looks really nice post more pics! Electric start is a great thing!
I would suspect it would be possible to start the bike with ez start cams with the kicker, but probably not ideal.
I would call S&S to confirm as well.
S&S still offers their standard grinds in NON EZ start, which will be fine for your bike since you didnt mention running high compression pistons or big bore.
I wanted just before to contact S&S , to know if somebody did it before me here
I sse I aml the first who will try it ...
the other face of my BoB ... with a Ultima vintage belt in 2"
my question :
the answer is arrived quick :
Brent Glick, S&S Cycle Inc., 14025 Cty Hwy G, Viola, WI 54664, Ph. (608) 627-0242, Fax (608) 627-1488, bglick@sscycle.com, www.sscycle.com
YES ... perhaps ...now I know , it's not possible ...BUT --> WHY ?
I would like to understabd why not ?
for my DYNA 2005 TC88-A EFI Transformed with a CARB MIKUNI-42 ,a ALTMANN ignition KN filter, and Pirate pipes. looking for the ESAY start 510 to ùmod my OEM chain cams my friends say that I will not start the engine with the KICK , due to the lack of compression. Tell me that I will succed to start my dyna with my new kick and EASY START cam.
You would not be able to use an Easy start cam with kick start.
