J&P Lowered kickstand question
So i have a 2010 street bob with a burly slammer kit on it front and rear. Bought a 1" lower stand pn 5300345 from JP cycles. I installed it but in the up position it rests on the primary not against the frame. Any one else have this stand on here? Am i doing something wrong or is that just the way it is?
I ordered that stand and had the same issue. Pretty sure that stand is made for the pre 06 dyna's that had the 5-speed and the shorter primary, even though the site says for all Dyna's. I think the label on the packaging said 99-05.
you can grind a bit off the tab that will allow the lowered bike to sit at a better angle, but without re-bending the stand you will need to lean your bike to the right to swing the stand out.
