Please Help with Power Vision
Good Morning everyone. I got my bike and an PV last year. I messed with the PV last year b4 they had the actual auto tune enabled. I updated my PV reflashed the Tune I got from FM so i could start over and use the new autotune feature however when i go to try to flash the FM using the auto Tune i get an error message Tune Missing Closed Loop Bias. How do i fix this?
First make sure and use pv update client, there has been a recent update to the software and firmware, as recent as ,well as I was writing this I checked my PV and there is a firmware update this morning! Hopefully you have a clean copy of Jamie's map because it sounds as though yours may be corrupt if not try with the one you have. After you update your firmware and software load the fresh map into Winpv, once it says tune is ready for editing look to the top where it says PowerVision, click that and from the drop down menu click update tune using PV, click yes and the WinPV will update the tune. Then send that upgraded tune to a new slot on you PV then take it to your bike and flash the ecm with it. After that is done select program vehicle-AT- enable AT and don't forget to save the results (export learned) in another slot before you turn off your key. Re-flash with your exported tune (or go back to Jamie's) cause otherwise your constantly running with the tuning map.
Where???
I see the update announcement here (for Firmware Version: 2.0.2-1238) but this version does not appear on the D/L page.
Hep a bruddah out?
Hep a bruddah out?
Like RatTrap said LOL!
@Sidewind75 you are going to have to speak with Jamie about that, my bike is a '08 and has the O2 sensors. Have you checked all the dynojet instruction sheets? For now just use the copy of the original tune Jamie sent you. Or you could use your bikes original tune for the meantime, I'm sure no harm will come of it just go easy, Monday's coming!
Alternatively go to this thread and ask there lots of different bike owners there. Just reach out hopefully someone will be reading there tonite.
https://www.hdforums.com/forum/elect...-by-admin.html
jluvs2ride
14
05-19-2010 12:15 PM
