friend wants to trade his 06 mag wheels for my 13bob wheels, what do we need?
05-18-2013, 06:03 PM
what do we both need to purchase in order to just do a swap? never done a wheel swap
or is it just as simple as remove and install?
05-18-2013, 06:10 PM
Will not be a simple swap. Bearings are not same. Only 06 and 07 dynas can swap wheels without changing anything. Those with more knowledge can verify this and tell you why.
05-18-2013, 07:49 PM
J is correct, u guys need to swap out the bearings and the rest should be good to go
05-18-2013, 08:02 PM
Hell yeah! I would do that trade immediately.. Lol
05-18-2013, 08:05 PM
ok
so if i want his 06 wheels..i have to use the 06 bearings correct? and the bearings are inside the actual wheel?
05-18-2013, 08:13 PM
U need to put your 25mm bearings and wheel spacers into his wheels basically to run them. I'd use new bearings unless they have low mileage
05-18-2013, 08:19 PM
Quote:
Originally Posted by
gant
ok
NO The 06-07 have 1" axles and I think you have 28mm axles. You need the change the bearnings and sleeve in the wheels
05-18-2013, 08:22 PM
bearing and spacer kit from Harley for the front and rear wheel. 2006 is a 1" axle, 2008+ are 25mm axle
BIG job...expensive too!
~Joe
05-18-2013, 08:31 PM
do a search for wheel bearing replacement and you see it's not hard to do or that expensive
05-18-2013, 08:38 PM
gant
ok
Yes, but I would use new bearings..
