fuel regulator replacement Help?
I'm changing my fuel regulator and cant figger this out--it doesn't look very secure a seal-how does the larger o-ring get installed? there is a green plastic ring that goes on the new regulator and then an o-ring----does the oring just slip onto the regulator below the green ring? this doesn't seem like a very good seal--I tried to put the oring on the green thing but then it cant fit into the regulator housing and the clip wont fit--It doesnt seem like a good seal and I wonder if I'm missing somethin?
