Having recently crashed my 2007 Wide Glide, I'm needing to replace the front end. Was going to go with the stock HD forks, only in chrome with PM 6 caliper brakes. Would you put on different forks/triple tree?
Great idea. So these ricor intimidators just fit on top of the regular "shock" assembly? Stiffer ride? I like the FXDWG ride pretty well - smooth and predictable. I mostly ride twisties in the hills, aggressively.
INTIMINATORs sits on top of your stock damper rod forcing the oil through high-quality deflected discs found in top of the line shock absorbers. When the front tire hits a bump then the inertia of that bump opens the inertia valve instantly allowing for a faster response. Installation is easy. Drain the fork
oil, remove the spring, drop in the Intiminator, add oil then the spring and away you go.
