Installing exhaust issue - studs wont stay fit
Old 05-21-2013, 01:02 PM
GeneBinderFXDB's Avatar
GeneBinderFXDB
GeneBinderFXDB is offline
Default Installing exhaust issue - studs wont stay fit
I just put new exhaust, intake, and tuner on my street bob. When I was removing the old exhaust, 2 studs came out with the nuts out of the cylinders. The nuts were seized on. After doing some research, everything I read was to put a little anti seize on them and screw them back in. That worked well on 3 of the 4 studs...one doesn't want to fasten. Once the nuts gets flush with the flange it just keeps spinning and will not tighten. I have all four new flange nuts and new gaskets on there. I am fairly certain that the antisieze is preventing the stud from locking in place....or preventing the nut from locking. Any suggestions on a solution would be very much appreciated.
Old 05-21-2013, 01:27 PM
Chiledog's Avatar
Chiledog
Chiledog is offline
is the stud spinning in the head or is the nut spinning on the stud?
Old 05-21-2013, 01:35 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
X2. It isn't the antisieze. Something is striped. Let's hope it's the nut ( hexnut ).
Old 05-21-2013, 01:44 PM
GeneBinderFXDB
The stud is spinning not the nut. I had a similar experience with the other stud that came out but after i took some of the antisieze off, it fit tight and i got it fastened.
Old 05-21-2013, 01:45 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
also... if it is not the head that is stripped be sure you use a TQ wrench when you install! those are very specific on tq specs so you do not strip them or snap the stud
Old 05-21-2013, 02:24 PM
GeneBinderFXDB
I just went back out and took the hex nut off that I picked up at harley this afternoon. I was able to get the hex on about half way up the stud at which point it started spinning (this was earlier...at which point i decided to post on the forum and see if anyone had any suggestions. I just took it off nut and the hex is half stripped on the inside, wasn't stripped before, and the stud is securely in place. i ran my fingers over the stud and got a nice coating of antisieze off. I had serious problems even getting it threaded to begin with. I know both parts are the right fit (this is the third nut i have experienced this with). I can help but think the antiseize has something to do with it. Anyone ever experience this? or have suggestions? What can I use to strip the anti seize off?
Old 05-21-2013, 02:38 PM
Good_Apollo's Avatar
Good_Apollo
Good_Apollo is offline
Gotta go easy on the anti-sieze. Too much and the pressure of it will strip the threads in the head right off, that is bad news. Sounds like you may be ok now, but careful if you ever have to take those off again
Old 05-21-2013, 02:44 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
I guess if you put to much antisieze into a blind threaded hole that it could cause tightening issues. But never heard of antisieze causing threads to strip. I think the problem is a loose nut. ( No Pun Intended )
Old 05-21-2013, 03:34 PM
GeneBinderFXDB
I'm pretty sure the problem is that the nuts are finely threaded and the addition of antiseize made the initial threading harder. Lack of access and visibility ads to the likelihood of an off-center initial thread. "forcing" the nut on likely cross threaded it and hence the stripping. the antiseize was just there to lubricate the party.
Old 05-21-2013, 05:47 PM
maddghost's Avatar
maddghost
maddghost is offline
The grease won't inhibit the bolt's ability to become tight, but if there was really too much in the head part it could create a pressure which would not let the stud reach the end where it seats. Just a thought. If the head thread is stripped you can use a helicoil to the threads, as long as you can get your drill plumb, if you can't I guess the head will have to come off. Of course if it is just the stud you accidentally stripped pass a tap into it before you try the next stud.
Quick Reply: Installing exhaust issue - studs wont stay fit
