Super Glide Custom Suspension Upgrade Update
Havent checked-in here in a while and thought I'd give an update on my Dyna and the suspension upgrades.
I bought an '09 because I like the silver engine and drivetrain. Soon after purcahse, I had the EFI flashed to a 103 Stage One map by the dealer, replaced the stock filter with a Screamin Eagle (SE) filter and back plate and installed a pair of modest SE slip-on tapered mufflers.
I made the following suspension upgrades - installed drivetrain Sputhe Stabilizer, Ohlins 909 rear shocks, Works nitrogen cartridges in the front forks, FXR beveled foot pegs and low-rise Sportster handlebars. All of these suspension upgrades totalled about $1500.
I've recently rolled about 25,000 miles on the machine and everything works fantastically. This Harley will run with other (european) bikes I have. You can lean it hard in the curves and there is no wobble from the rubber mounts. The stability and ride quality provided by the shocks and the fork cartridges is superb. Also, you don't scrape stuff since the shocks and proper springing sag raise the bike about 1 1/2 inches.
The engine output is more than adequate and I have passed-over several inspirations to boost it up to a 103 or 106. On curvy mountain roads I tend to stay in 3rd with an occasional visit to 4th gear.
When covering ground quickly on the interstate, the 96" motor delivers 45 mpg between 80 and 90. Slower backroad running in 5th actually reduces the fuel mileage down into the 40 range. I very seldom use 6th unless I'm doing 70 or more.
This is one helluva set-up. I realize different people like different things. For a lot of people "suspension work" means lowering the bike. That's fine. Ride what you want.
If you want greater road performance closer to that offered by the Guzzis and the BMWs etc, it is close at hand with the Harley. You do not need to spend $1500 on your forks alone or hang weird-looking high-dollar remote reservoir shocks on the rear. Sure, they'll work but the reasonable add-ons that I made really boost the Dyna to a new level of road performance for a modest outlay while preserving the original appearance of the bike.
I just completed a trip of about 2500 miles that included running the entire length of the Blue Ridge Parkway and Skyline Drive from Cherokee NC to Front Royal VA. Awesome ride on an awesome road bike.
It's amazing what a good suspension package does for your bike...and you put a lot more thought in it then just throwing on some progressive shocks.
Now that you have the suspension....work on that motor...the HD download and your slip on are your weakest links. Put some of the same thought you put into your suspension into your motor...then you'll really have something
Hello , I just ordered a set of Works Street Tracker Rears Shocks for my 13Dyna . They suggested to use their Fork Cartridges and Springs for my front end . Could you let me know more about your experience with their Cartridges ? I haven't really seen too many reviews on them . Thanks
Honestly, I imagine a pair of Race Tech Emulators with maybe a set of their springs would work good too.
For sport riding, this thing does just fine. In 3rd it pulls linear and strong up to triple digits! 4th puts it way over the top. I get 45 mpg at 90 on the interstate !
I also have a BMW R12S that's just over 400 pounds and pulls 130 hp if I want more g's.
