Help/Advice on wiring Tour Pak Lights on 2013 Street Bob
I have a King Tour Pak with Turn & Brake/ Run lightsthat I want to install on my 2013 Street Bob.
The Tour Pak lights use bulbs. The rear turn/brake/runlights of the bike are LEds. The front turn of the bike are bulbs.
My Questions:
Thanx
My Questions:
- Is it ok to mix LEds & Bulbs at the rear of the bike?
- Should I install LED Bulbs in the Tour Pak?
- If using bulbs of Tour Pak, will the existing wiring of the bike be sufficient in terms of load factor?
- Can someone please give me the part description / part number for the Stock Rear Turn/Brake/Run light wire connector that connects the LED harness to the bike connector under the seat.
- I plan to make ‘Y’ shaped wire harness with the connectors, so that the stock & tour pak are a simple plug-in & plug-out, without any splicing etc.
Thanx
I installed the Harley LED tourpak light kit on my non LED Road King. They feed off the same power cables but are controlled separately with their own electronics. Assuming you have a similar setup, I don't see why not. I also put a tail light conversion kit on my bike, again separate controller.
