Rear strut/ fender options
Well, as many of you know I got rear ended on my bob last week, and it was pending being totaled. Well overall the bike was in good shape, minus the rear. And they decided not to total it. Instead I am getting a check to have a bunch of stuff repaired or replaced. Most of the things on the list took a very small scratch, which I plan on having touched up instead of buying all new parts. The big ticket item here is the frame, which I need your help with.
The struts are connected to the frame, and so with them being bent, its a whole new frame. ($3000) Well, here's my question. Since we'd all rather have that cash in the pocket, judging by the looks of the struts, would you say I could A) Have a shop bend them straight 'er' by heating or what have you. B) Cut them past where the bends are and tweak/modify a rear fender like a few of you have done. Or C) Just have them replace the frame. (Bike will be down 6-10 weeks)
Not quite sure what to do, I do still want a passenger, and from what I can see the struts are only really off 1/4-1/2 inch, with the bend being on the left strut about 3" past the tail light.
What should I do? Ideas?
Replace the struts entirely. They are filled with fluid and are toast at this point. No way around that. REPLACE THE FRAME! The bike will NOT ride true at all with a bent frame. They are paying to have it fully restored to be a safe bike. Most likely you tell Harley you are not going to replace the frame they wont let the bike out of the shop as its a huge risk. Its going to be down for a bit BUT it will be like new. I know the 3K sounds nice in your pocket however its not going to make the bike safe nor will you be happy knowing that there are bent parts on your bike.
Struts are filled with fluid? What? Its not just a piece of metal supporting the fender and passenger?
And, it may not look it in the pictures but, the struts are really not that out of place... Maybe its just wishful thinking but, from what I've seen and been told, the 'frame' damage stops just past the tail light so it wont change any ride quality either. Unless chopping struts changes that... maybe someone who's done it can chime in.
remove the fender, slide a big long pipe over the strut and bend it back,, it.may need to be heated depending where your trying to bend it.... I had to bend my struts out about a half of an inch to get a 200 tire on my bike.. the fender struts have nothing to do with your bike rolling true,, there only there to support your fender and passenger... you could completely cut them off if a passenger wasn't a requirement
It all depends.. If you are the kind of guy who likes everything close to original... Then i would definately get them to change the frame. Otherwice if you are handy yourself and would like to spend some of the money rebuilding your bob and it is only the struts that is bend i would do this:
Cut the struts..
Buy the voodoo fender kit with bolt on fenderstruts
Buy a used rear rim on ebay
Slam rear end
But there is a lot of ifs... I dont know rules in your country with cutting the frame. Or how bad damages are.
Cut the struts..
Slam rear end
Well, the damages are minimal. I'm thinkin it can be bend straight enough to get a new fender put on and then carry on as usual. If I can't get em bent back, I'll have to modify the struts and create somethin new.(Which might be fun)
I'll be seeing the bike Monday, its still down at the dealership as of right now. Goin on 2 weeks without my bike. Its hell.
Cut the struts..
Slam rear end
Cut the struts..
Slam rear end
