Bassani customer service sucks!!!!!!!!!!!!!!
So I have an issue with my bassani baffle. It comes loose after hard riding. And when I mean loose I don't mean the nut and bolt that holds it in. It's loose inside at the rear of the baffle. Sounds like ****!! Kills the great sound the 1d5250 makes. Anyhow spoke to Kurt at Bassani and provided him with the invoices he requested so he can send out the new baffle to fix this problem. It's been a month now and no email reply from him. I call him up he pulls up my email and reads off my number to me and says I will call you back ? Well he never did! **** them! So currently I'm running it with no baffle. Sucks that we spend hella money on there product to be treated like this. My bad for venting but **** a whole month is bull ****. Oh yeah I also have an issue with the brake lever hitting the dam heat shield. FML
When I was dealling with them, it was very hard to get return calls. But every time I called them I was able to speak to the customer rep or tech rep. I understand that they "might" have a lot on their plate dealing with more than just motorcycle parts. I have found that the best way to resolve an issue with a company that doesn't have time to return the customers calls or emails or whatever is to be annoying, call them all day everyday until the issue is resolved and then never deal with them again if possible.
I think Kurt is the only tech guy there, at least for motorcycles, i have worked with him and he was a lot of help, but it's hard to get things moving for sure, I think he probably needs a backup or something.
I have not had a good experience with them as well. Their product and tech support are crap. I will be going with a different exhaust next time around.
1) A weld on my mounting tab broke clear off (also happened to my friends bike with the same exhaust, in the same spot)
2) I wanted to try some different baffles and cant get a straight answer about what size I need/if they have any replacements available. I have called numerous times and sent numerous emails with no responses.
At this point I have given up and will just deal with it until I have the money to replace it.
Sorry to hear about your 5250 tho... hopefully they can straighten it out for you. I guess there isn't a temporary way to fix it is there? Other than taking it out?
