Please help!!!!!
Please help!!!!!
I am new to the board and have a problem with my 2000 super glide. I went for a ride today and all of a sudden when i went to stop it would die.then i would start it right up and the go til i had to slow down again. I had to keep on the throttle so the bike wouldnt die til i got home. Now it wont start. Or it will start then die a few seconds later. I need some help as it is my only mode of transportation right now. It has a stage 1 screaming eagle kit on the carb and screaming eagle 2 pipes. Please help me
There are several things that can go wrong, First thing I would check are the plugs, they may be fouled, as the symptoms you describe are just like fouled plugs,replace with known good ones, next there could be dirt in the carb, remove the bowl and check the jets to make sure they are not blocked. Check plug wire connections at the plugs and coil, all these things should take an hour or less to check.
One time my bike died and could not figure out why it did, then I decided to play with the ignition switch, by wiggling the key, found out my ignition switch was worn out.
also check battery connections. All these things are quick easy checks, if these are all good then time to dig deeper like crank position sensor , good grounds etc..
Did it run better after replacing the plugs, carboned up plugs indicates a rich mixture, too much choke or stuck choke, may need to pull carb off and give it a good cleaning, and blow out passages with compressed air.
flow bowl might be out of adjustment and flooding the carb
did you adjust the air/fuel mixture screw
