oil TYPE, NOT BRAND
What to use where? Get ready for the debate. My personal opinnion, use the correct oil for the correct hole. Crankcase, Gear and Transmission.
Proper oil weight
I agree!!! I have done the research. AND, my mechanic agrees. I use Mobile 1 V twin 20w50 in the motor. It's full synthetic and can be purchased at Wall Mart for 9 bucks a quart. I use Royal Purple tranny fluid (also synthetic) and Drag specialties primary (petroleum base). if you use synthetic on the clutch it will slip. DO NOT buy into Syn 3. Its crap!!! I change motor oil every 2500 mi. and tranny and primary every 5000.
primary oil
I just did a change on my primary oil, I went to the HD shop to get some primary oil and they said to run the same in all 3 holes. 20/50. I put it in the primary and now it seems to grab more on take off's I even killed it trying to take off at a slow rev. I don't know what was in my bike.. this is the first oil change.
is it normal for the 20/50 oil to do that?
will it get better as the oil breaks in?
I am going on a trip in 2 days and will be loaded down...I don't want to kill the SOB on a tight turn take off...I have seen a guy brake a leg by it falling on him..
Got my bike with a hair over 1,000 miles on it and have been using Screamin Eagle full synthetic 20/50 in engine and primary ever since.
In trans I use Spectro 75/140 6 speed platinum gear lube.
Would never use or recommend 20/50 in trans even though manual says its ok.
sweet street glide
Oil Archive (no new posts)
35
03-01-2008 07:54 PM
