Fork Tube Scratch / Leak
Old 07-16-2013, 11:53 AM
Supra8903's Avatar
Supra8903
Supra8903 is offline
Exclamation Fork Tube Scratch / Leak
Hello all.
I have a 2008 FXDC which I bought used last summer.
Last weekend I had it out for a ride and noticed a ring of oil on my right fork tube. It was at max travel, and there was a thin film of oil on the tube.
I cleaned it well and compressed the front forks a few times, and cleaned it again.
I took it for a ride yesterday, and I did not see a leak, or a ring of oil, but I did find a scratch on my tube after closer inspection.
The scratch starts at the dust cover and goes up (toward the triple tree) about 3 inches. I can feel it with my nail. It starts deeper and gets fainter as you go up. Should I continue to ride it, or swap out the tube and seals?
Also under max compression there is a clunk and a rattle sound from the front forks... is this normal? My fathers Sportster does not sound like this.
Thanks,
Joe
Old 07-16-2013, 09:01 PM
nevil's Avatar
nevil
nevil is offline
That scratch could be from a bad fork bushing. Probably need new seals and bushings and if the scratch is that deep you also need a new tube.
If it's been leaking for awhile the noise from the front end could be from a lack of fork oil.
A clunk could also be a loose tank bolt or worn/shot front motor mount, these can sound like they are coming from the front end.
Old 07-17-2013, 05:10 AM
stilup's Avatar
stilup
stilup is offline
You must be loosing more oil then you think.
Don't risk it , check it out.
Old 07-17-2013, 08:07 AM
ynots's Avatar
ynots
ynots is offline
The clunk could be your steering head, might need to adjust the fall away.
Old 07-17-2013, 09:23 AM
scooter1128's Avatar
scooter1128
scooter1128 is offline
you will need to replace the fork tube to stop it from leaking. my wg had a small nick/scratch on one of the tubes. i tried emery cloth to make it smooth. after replacing the seal a second time...i gave up and bought a fork tube. not that expensive. rlaced that with a new seal and leak free!! any doubts, replace the fork bushings as well...not expensive and you'll already be in the fork. good luck
Old 07-17-2013, 09:56 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i have done fork rebuilds on guys tubes that have been sanded with 220 for paint (and the paint of course failed) they still hold up fine and no leaks... i woiuld just toss a new seal in there, will be fine
Old 07-17-2013, 10:41 AM
Good_Apollo's Avatar
Good_Apollo
Good_Apollo is offline
I had a small scratch in mine at one time, got caught in some nasty muddy dirt roads and I'm guessing a piece of sand scratched it. I cleaned everything really well and a few months later the scratch was gone, no leaks
ronsspas
03-21-2017 12:38 PM
itsmf
01-20-2012 07:25 PM
MemphisAstro
EVO
11
09-18-2011 09:45 PM
QS78
07-28-2009 08:15 AM
Quick Reply: Fork Tube Scratch / Leak
