How can I remove my front turn signals on my 2013 street bob? I used to have a sportster and just followed the wiring to the harness but it seems to be a little more difficult on the dynas due to the fact that the wire goes through the switch housing.
Thanks
On the side of the neck/frame there are 2 rubber plugs. Pull those and the connectors are under. Should be able to disconnect them and just pull the cables through the bars. May need to pop the pins out of the connectors to get them out of the bars.
not sure if this is what you're looking for...but on my 2013, i relocated my turn signals to fork mounted ones (Joker Machine LED). You just cut the old ones from the bars, and then there are new deutsch connectors inside the frame that you plug into with the new ones. It's different than the way 2012 was.
