fat bob oil change
fat bob oil change
Change the oil yourself he said, SO not being the handy type, i gather OIL and oil filter, get my hefty *** on the ground, and find the HEX oil plug blocked by other parts of bike. SO my question to you Doers, is, Must i cut a HEX WRENCH smaller in order to FIT the space( those who own a 13 Fat bob and changed oil will know) Or is there another way of removeing the Oil Plug>>> Also how do you guys prevent the oil from filter from going all over your bike. YEAH IM saving Money by doing it myself and im haveing SO MUCH FUN,
I always use a small piece of cardboard, fold it into a V and stuff it under the filter before removing it.
Oil Changes
The plug, in fact all the drain plugs, are 5/8" outside diameter. I use a 5/8" universal socket to remove mine. As far as the filter goes, I punch 2 holes in the end of the filter, at 6 and 12 o'clock, so the oil can drain into a spillway and into a bucket. I let the filter drain all night and in the morning I just take the filter off and there is no residual oil to spill. You need to get the oil warm by riding the bike a while before you start draining it. Taking out the filler/dipstick will help it come out smoother and not glug-glug.
if you dont punch holes in the oil filter as mentioned above be prepared to watch it run all over your motor mounts. I get mine up to operating temp before I dump the oil to suspend all the contaminates and help it drain faster. I let the filter drain for 1/2 hr after punching holes. One of those thin flexible cutting boards cut down works great to make a trough for draining the filter
I know what you mean .. when you read some questions you have too wonder their skill level/common scence... I recommend if you must ask very basic questions please get some one too teach you the basics first ,, we all must learn new skills ,,, classic one how do I remove handgrips, a 2 minute job once the bars are stripped off HOT water in a jug
