Fitting a rear fender, need guidance.
So my new fender came in today. It's a long fender and has zero holes in it, so I get to put them in!
I need some guidance on how to make sure my new fender is sitting in the right location, height wise, so both my seat mount and passenger pillon mount to it like the currently do on my stock fender. I would hate to get the fender lined up with the lines of the bags and have it sitting to high or to low where I can not mount the seat.
I am thinking the I would find a way to strap/secure the seat to the bike so it does not raise up when adjusting the roll, and height of the fender, using the seat as a guide.
Thanks for any help you can provide.
Sounds like you're on the right track. I'd take some measurements of where they're at, if you still have the stock fender on. If not, you can rest seat on the bike, and hold up your fender to where its going to sit, and see how it aligns, then make your marks.
Nothing a little tinkering can't solve.
Just remember, measure twice, cut once
you will pay for a good steel fender.
This is who I get fenders from.
Make sure your sitting down.
No one will beat their quality. Prep is easy on their fenders.
http://fatkatz.com/index.php/products/fenders/
Forgot, using the seat to set up the drilling is a good way to do it. I measure 3 direction on every thing I drill. This will keep it straight, and level.
Well I got the fender fitted last night after some cutting for clearences (belt, caliper and saddlebag support cross brace). If anyone was to go this route, I would suggest getting a (glass) fender no more than a .25" narrower then the struts. I went with the stock width at 8" and the fender does stretch like the steel stock one, just not as easily. I ust need to do some fine tuning on the cuts for apperrence, then I can start fitting the filler plates. Here are some pics.
