Rear Fender Hole Plugs
Old 08-07-2013, 11:04 AM
Jr Bob Dobbs's Avatar
Jr Bob Dobbs
Jr Bob Dobbs is offline
Default Rear Fender Hole Plugs
Ok, got a 11 SB there are two holes rear fender chrome 3/8 in found that one at Lowes. The other hole located close to tail light have measured 1/2 in no 7/16 in no what is the size of that hole dam't it. Could it be 5/16?
Old 08-07-2013, 11:44 AM
ynots's Avatar
ynots
ynots is offline
can you size it with a drill bit?
Old 08-07-2013, 01:48 PM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
The rear hole has a notch in it for the seat bolt.
You can add a stainless pan head screw with a stainless washer and no need to do anything else.
Old 08-07-2013, 01:58 PM
ynots's Avatar
ynots
ynots is offline
I put one of these on it and use a stainless steel panhead screw
ynots's Avatar
ynots
ynots is offline
double post
Old 08-07-2013, 02:12 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
You could cover the hole with a rubber fender plug p/n 10228:
Old 08-07-2013, 02:41 PM
Jr Bob Dobbs
Got one of those now with a seat screw attached just wanted everthing to match. Maybe drill out a bit so the one of the other sizes will fit.
Old 08-07-2013, 02:50 PM
DoomGloom's Avatar
DoomGloom
DoomGloom is offline
You should totally drill through your fender!! Please take pics, so the rest of the forum can credit you for this mod! Best of luck!
Old 08-07-2013, 03:48 PM
Jr Bob Dobbs
Doom, you shouldn't believe everything you read, kinda makes you sound foolish.
Old 08-07-2013, 07:46 PM
99%r's Avatar
99%r
99%r is offline
Harley makes plugs
Quick Reply: Rear Fender Hole Plugs
