relocate turn signal wires
There should be an extra hole in the fender under the stock plate bracket. I put a rear turn signal relocation kit on mine that came with another bracket that had an extra hole in it. When I took the stock bracket off, there was an extra hole in the fender with a plastic plug in it. You just pop the plastic plug out and run the wire through the hole.
I just installed the relocation kit on my fxdc and to get the original bracket off you can take the nuts off of the back inside the fender. I originally thought the same thing when trying to get to the screws, but you can pretty easily get to the nuts between the tire and rear fender. Once that is off the extra hole will be exposed.
Lockeshill
04-24-2016 08:33 AM
