Quick detatch sissy bar AND bags at same time??
is it possible to do this?
I have 2010 SB with the quick detatch kit and currently run the HD quick detatch sissy bar. Would love to add on a set of quick detatch bags for the longer trips while keeping the sissy bar on for the lady. Which bags will look best and work for me? Appreciate the help!
bschones, Squidhead and some others have been recently discussing this topic in relation to the Leatherpros FXDXT retro bags. The entire thread is https://www.hdforums.com/forum/dyna-...installed.html
Below is the general gist of what applies to running the bags with sissy bar. Again, this is just about the leatherpros bags and Garry's response.
Originally Posted by Qdog002 View Post
I see what you mean. What if you mounted the bags first, then attach the backrest? If that won`t work, then only other option would be to grind down the lever and weld an extension on so the lever would be past the sideplates.
What do you think?
The problem is the bent over "tab" in the handle that we put there to be able to lift the lever up with your fingers. This "tab" doesn't need to be near as big as it is since you can use the leather carrying handle to lift up the lever mechanism. All bags that we are now shipping have a very sort "tab", just big enough to allow you to comfortable push it down into the latched position. The easy fix for the bags out there already is to trim off all but about 1/4" of the "tab" with a hack saw, file off any sharp edges, and touch up with a little black paint. This will give just enough clearance to close the latch with the sissy bar on. You probably still won't have enough room to take the backrest off without removing the bags first though.
Garry
__________________
What do you think?
Garry
__________________
lizdc
Softail Parts
04-30-2017 05:23 AM
