Turn signal problem
Turn signal problem
Hi everybody,
Just bought my first Harley--a 1,700-mile '10 Fat Bob from a guy who decided motorcycling wasn't for him--and I'm loving it so far. Really great bike--so much fun!
One little issue, though. It failed its state (Maryland) safety inspection because the left turn signal doesn't "work right" according to the inspector. Actually, it functions perfectly--but for some reason you do have to push the button on that side harder than other side to trigger the signal.
Anyway, I thought it was kind of a weak reason to fail the bike, but I want to fix it. What I'm wondering is, Have any of you guys had similar issues? And if so, what ended up being the solution? I don't have a shop manual for the bike yet, but I'm thinking I'll start by doing a little exploring inside the module on that side--maybe see if I can get to the switch itself and use some contact cleaner--but I have no idea what I'm in for there.
Anyway, appreciate any insights. Just trying to avoid unnecessary trips to the dealership.
Thanks!
Thanks!
Disconnect the negative from battery. Cover bike carefully with a blanket and padding. Get you a stool to land stuff on and remove clamshell around switch. You may be lucky to find some crud under the rocker but doubt it. It's probably broke internally no older then it is from a blow. I think the replacement is going to come with short leads. It needs to be soldered in and shrunk wrapped. Do not let this be you first learning experience with solder and patience. It's tight in there.
Thanks, Ripsaw. Based on that, I'm thinking that unless it's something obvious, like crud in the switch, it'll be going to the shop. I don't consider myself good enough w/ a soldering iron to attempt a fix in tight quarters.
Out of curiosity, why the cover/padding for the bike? Just general precaution because I'm working on it?
First off welcome to the family. I am just a little sounth of you on the St. Mary's side of the bridge.
I would do what DesertDyna said and take it to another shop. Where did you take it anyways?
Your lucky its the left housing, that right one needs some specail care when pulling it apart, the left is cake. You could have some junk in there or the rocker cover could be cracked or broken not letting it make a full rocking motion and the reason you need to push a little harder/more.
Sorry, your a little futher north than I was thinking, I was thinking Prince Frederick for some reason. Anyway, I hope you get the problem worked out without to much trouble.
Regalzack
06-22-2019 11:35 PM
