Most cost effective way to run 16 inch front wheel on SB 2011
Old 08-23-2013, 07:44 PM
missedem's Avatar
missedem
missedem is offline
Default Most cost effective way to run 16 inch front wheel on SB 2011
I really want a bigger front wheel on my front end . Do I have to change out the triple trees etc. when I do this. I am wanting to run a 16 inch front wheel and tire. thanks for any suggestions and input. I am not new to bikes or mods but not sure how to go about this one.
Old 08-23-2013, 07:47 PM
ynots's Avatar
ynots
ynots is offline
you planning on lowering the rear end?
Old 08-23-2013, 07:52 PM
missedem's Avatar
missedem
missedem is offline
no keeping stock rear end . I did put 12 inch progressive 444s on and they work really well.
Old 08-23-2013, 08:47 PM
WG2011's Avatar
WG2011
WG2011 is offline
Bigger front wheel at 16 inch what is stock
Old 08-23-2013, 10:29 PM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
wideglide trees and crossbones wheel on mine...wasnt to costly
Old 08-23-2013, 10:31 PM
SuperFastGlide
19 is stock... he means fatter, which the 16 is, plus it has a taller profile...
Old 08-24-2013, 01:25 AM
b2inUT's Avatar
b2inUT
b2inUT is offline
Side view please.
Old 08-24-2013, 06:27 AM
AFMM3's Avatar
AFMM3
AFMM3 is offline
Fat Bob trees, FXDF or FLH axle and a 16 inch wheel with bearings to match your axle (1 inch or 25mm axle will fit your forks). Keep your brake rotor, caliper and spacers. If you use a Fat Bob fender, you would have to redrill the mount holes. I did this to my Street Bob in my signiture picture and to my kid's Nightster. Here is a picture of the Nightster.
Old 08-24-2013, 06:28 AM
AFMM3's Avatar
AFMM3
AFMM3 is offline
Here is a picture of my ex-Street Bob
Old 08-24-2013, 06:38 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
I bet the bigger tire will make the bike handle very nicely (not that it doesn't already). Why not find a set of stock rims for the Street Bob and use the front hub and rear rim and wire it up for the front of your bike, then you can run the 17" in both spots without making it look a little odd with the 17" out back and 16" up front. It's just my opinion, just seems like it might look strange with the smaller rim (not tire) up front, I could be wrong.
Quick Reply: Most cost effective way to run 16 inch front wheel on SB 2011
