pecking sound
Old 08-26-2013, 07:48 PM
11WGinWV's Avatar
11WGinWV
11WGinWV is offline
Default pecking sound
I have a 2011 wide glide and when I ride it for very long at all it develops a pecking sound coming from the engine, has anyone else experienced this. just curuious so I might no what I'm looking at spending before taking it in to have it fixed.
Old 08-26-2013, 07:49 PM
11WGinWV's Avatar
11WGinWV
11WGinWV is offline
bike has around 8,000 miles on it
Old 08-26-2013, 08:39 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Do you use synthetic engine oil? A lot of people including me hear sounds like that when using synthetic oil.
Old 08-26-2013, 08:59 PM
nevil's Avatar
nevil
nevil is online now
Does the sound change with engine speed, road speed or does it happen all the time? Any gear/gears in particular?
Old 08-27-2013, 04:49 AM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Which side of the engine?...top or bottom end?
Old 08-27-2013, 09:12 AM
11WGinWV's Avatar
11WGinWV
11WGinWV is offline
the sound seems to be coming from the top of the motor on the primary side of the bike the noise increases with the engine rpm but can be heard in all gears bike uses synthetic. You hear it once the engine warms up but once it cools off a little it goes away until the engine heats back up.
Old 08-27-2013, 12:26 PM
DravenGSX's Avatar
DravenGSX
DravenGSX is offline
Has it always done this or is this new? If new, have you made any changes recently?
Old 08-27-2013, 01:46 PM
pthauvet's Avatar
pthauvet
pthauvet is offline
from my readings on this forum and my own experience, if it sounds like a sewing machine... it is typical to a TC 96 valve train running synthetic. If its a distinct metallic noise (TIC TIC TIC)...that's pinging and go see a mechanic if you haven't made any mods, if you changed anything on the engine like cams, a good tune (adjusting spark as required ) will make ping go away, but to be on the safe side whatever was changed and how it was changed should be reviewed as well. Cheaper then an engine rebuilt
good luck
Nirvana
08-10-2021 11:00 AM
Robotech
07-23-2012 02:29 PM
CPL Haggard
07-12-2012 05:32 PM
clarsen2020
Engine Mechanical Topics
10-05-2010 08:24 AM
mikatt98
12-08-2009 11:26 PM
Quick Reply: pecking sound
