Progressive installation question
I will have some 13" 444 coming on friday. This is a trivial question, but has anyone installed it without putting the bike on a jack? The Service Manual recommends removing and installing one at a time. Is it easy to do that way?
Thanks, my mechanic skills are novice at best.
One at a time would be the way to go for sure if it's stock length but it might be tough for you to put one 13" shock on with a 12 on the other side...
If you're not going to use a jack you're going to have a hard time. The shocks are holding the rear of bike up, you need something to take the weight of the bike to get them off easily. Same goes for getting them on again, you're going to want the bike lifted enough that the space between the bolts is the same as the length of the shock so they'll slip on easily
You can manage with a car jack and a 2x4 if you're careful. Leave it on the kickstand and jack the rear up enough to reach the extra 1". Once you get one of the shocks on you can even downjack if you want. Although, I bought the sears motorcycle jack and have used it for many different things.
If stock length you can have a buddy help horse the bike around while you line things up (lifting rear end), doing one at a time. I had to do it in a parking lot with a buddy once when my shock bolt sheered off.
As mentioned above if not stock length you're going to have issues. Going taller you'll need to drop both shocks so the swing arm can widen for your new shock mount length.
