Right knee rubbing against the air filter, Wide Glide
Any suggestions on how to solve this on the recent model Wide Glides?
I guess either move the break pedal out about 2- 3" (haven't seen a product for this) or get a narrower air filter. What say you?
The constant rubbing against the air filter is killing my knee after a few minutes.
I solved it by replacing the AC with the HD Heavy Breather. Helped big time!
This pic is when I was measuring seat position, but you get the idea.
Moves the AC forward and gives more clearance
Also, try a different seat. My C&C Sport Tour adds another 3/4" clearance
This is on a Fat Bob, but the idea is the same
Fairly common problem. My Fat Bob was un-rideable until I fixed it.
For me it was a combination of things needed. I fitted an S&S teardrop air cleaner, which moved the outer edge of the cover inward about 1". I fitted 1" peg extenders. I put a Kuryakin Longhorn extended brake pad on. I also bent the rear brake arm out about 1/2" by brute force.
Short of bending the brake arm I did the same as Foxter. When I bought the bike it already had the S&S teardrop air filter and I replaced me stock seat with a Mustang vintage wide but it had no effect on this problem. After everything else it was the Kuryakin peg extenders that made the difference for me.
I wore the emblem off the oem AC with my knee. Never bothered me though.
