Fancy oxygen sensors that allow your EFI to cope with changes to air filter and pipes better than the stock ones....for my money I would go with a proper tuner like a FuelPak.
They aren't sensors.
They are a pair of resistors that are added between the existing sensors and the ECU as a voltage divider to increase the bias voltage on the sensors. This makes it look as though the engine is running lean and the ECU compensates accordingly.
Oh you can tell your an evo guy...Oxygen sensors? nope. All they are is a resistor that goes between your oxygen sensors and ecm to reduce the signal tricking the ECM into putting out more fuel.
