Seat removal and install???
I got a new seat and found it very difficult to remove the stock seat because of the seat strap.
How is the best way to remove seat?
What do you do about the strap other than wrestle it off and try not to scratch up your paint while doing so?
And in turn putting on a new different seat... Best way to deal with the strap?
I tried searching and did not get any results.
Exactly, just reach in there and loosen the bolt that the strap is connected to, then don't reattach... seat looks better with out (IMO).
I was like you when I first took the seat off, I thought jeez... how awkward it was to have those straps bolted to the fender!!
My old softail had them bolted to the underside of the seat and it was not nearly as difficult to remove the seat.
Bob
Because of the wide rear pillion on the Switchback, I was able to keep my strap switching between the stock seat and the Mustang but you might not be able too, so cut the strap and trash it. or If you must have it, wiggle your stock seat out( remove the fender screw, pull back and release the tank end of the seat, then twist the stock seat out of the strap{cup the rear bracket with your hand so you don't scratch the fender} ) With the seat off you'll be able to see the post and how adjust the strap. Then reverse the process to install the new seat.
And let me know how you like it.... That seat was really comfortable for a stocker.
