No turn signals
Old 10-02-2013, 08:48 PM
rsking45's Avatar
rsking45
rsking45 is offline
Default No turn signals
On my 2011 wide glide the turn signals and brake lights stopped working. The running lights work and when the alarm activates all lights flash as normal. All bulbs are good, wire and connections are good, I checked the fuses all good. Im kinda looking at the STT module? There are two connections that run off the STT. for the rear lights .When I check for power at the connection I only have power to the blue wire which is for the running lights. There is a violet wire for turn signals which has no power
Any Ideas
Old 10-03-2013, 02:18 AM
rsking45's Avatar
rsking45
rsking45 is offline
Ended up being a acc fuse. It looks fine but when tested with a test light its no good. Who would have thought the brake and turn signals would be on a acc fuse.
panhead_pete
EVO
03-28-2018 04:06 AM
mgbanks
06-15-2009 06:20 AM
NCCopBikeRider
01-25-2009 02:07 PM
vegasrock
08-23-2008 05:37 PM
Badbagger
01-16-2008 08:41 AM
Quick Reply: No turn signals
