turn signal relocation 2012 dyna
2013 Street Bob with Joker TS. The only issue is fast flashing dash indicators. It doesn't bother me.
I double check the stuff dealers tell me. My headlight bucket had a broken isolator and the service manager ordered a new one. Wrong! He ordered a standard headlight even though he knew I have a Daymaker. I had to tell the parts people what to order to resolve the warranty.
If you end up wiring it straight in and get the fast blinking caused by low resistance from the front turn sigs you can do one of two things to fix this. One-spend a good amount of cash on a load equalizer or spend little money and get Custom Dynamics TrueFlex Dual converter. It takes your three wire setup (purple/brown, blue and black) to a two wire setup used on most LED lights. You would need two, one for each side, and they are only $5 each. You just need to wire them into your system. I have these on my bike and they work great. They control the resistance between the running brightness and the flashing brightness while telling your system everything is working as required.
